Lower engine tapping noise. Now what?
Old Mar 10, 2010 | 11:26 PM
TBIAgent69's Avatar
Originally Posted by Chrisinhouston
I will do a thorough inspection in a few days after a business trip and report my findings. If it is a valve or lifter noise is there a remedy? Haven't looked at my RAVE CD yet but can adjustments be made in the tappets or rocker arms?
If it is a stuck lifter you can put a quart of ATF in the oil and it will clear it up in a week or so. If it's a dropped sleeve, go with the snake oil.
I do all the oil changes for my family and friends. My grandpa didn't believe in maintenance so he'd go 20+ thousand miles between oil changes. I'd make it a point to put a quart of the cheapest ATF I could get my hands on in the crankcase a couple of weeks prior to changing the oil and it'd always get rid of the tick.
My uncle is a master mechanic for Toyota. He always wanted to tear the engine apart and replace crap. I say try the easiest fix first...
Old Mar 11, 2010 | 08:23 AM
Shane83's Avatar
I put that Honey stuff in my wifes old mini van before she got a new Chevy Travers and it really made the check engine light go away... call me crazy or it may have been a big coincidence, but whatever!! Funny you put that up there!!
Old Mar 11, 2010 | 08:45 AM
No noise is normal, it indicates a wear issue, with no exceptions.
If you are getting this noise, you need to have a oil pressure test done. Leave it over night, check oil pressure when stone cold at an idle and at 2000 RPM's and again when warmed up at idle and 2000 RPM's.
Get back to us with those 4 sets of numbers and remember it is your engine, your expense, so do this yesterday before it costs you big time and by the way don't depend on any of the heavy oil additives to cushion a noise, this is just a short term fix that will still fail.
calbuild
Mar 13, 2013 01:08 AM
shelleyman
Jun 26, 2008 10:18 PM
scubasteve
Jul 5, 2007 03:18 PM
rwhite2001
Mar 9, 2007 10:24 PM
04DiscoOwner
Dec 22, 2006 09:39 PM
