LR Disco lose power and die. Hepl!!!!!!!
After drivivg around in Las Vegas heat with air on or off. My 95' Disco stalls/ loses power and dies every now and then or a couple of miles. I dont get it! It dont over heat now, at lease that my gauge is working and stays in the normal range. I cant figue it out. What system will kill the engine like that? I'm trying to get all the bugs out before hitting the trails. Please help me!!!!!!
RE: LR Disco lose power and die. Hepl!!!!!!!
Fuel temp sensor.
When was the last time you had a tune up?
www.atlanticbritish.com, check out their tech tips.
on
What about your fuel filter, when was it last changed? Might also want to replace your fuel pump relay, common problem.
Start running high octane or you will carbon up that engine and possibly do valve damage, on the good side, you will get about 2 more MPG and better performance.
Let me know if you can't find how to read the codes and I will send you a link.
