LR Disco lose power and die. Hepl!!!!!!!
Old Sep 11, 2008 | 11:39 PM
roverwoody's Avatar
Default LR Disco lose power and die. Hepl!!!!!!!
After drivivg around in Las Vegas heat with air on or off. My 95' Disco stalls/ loses power and dies every now and then or a couple of miles. I dont get it! It dont over heat now, at lease that my gauge is working and stays in the normal range. I cant figue it out. What system will kill the engine like that? I'm trying to get all the bugs out before hitting the trails. Please help me!!!!!!
Old Sep 12, 2008 | 12:38 AM
HoustonDM's Avatar
Default RE: LR Disco lose power and die. Hepl!!!!!!!
What kind of spark plugs do you have??
-Houston
Old Sep 12, 2008 | 06:47 AM
Fuel temp sensor.
When was the last time you had a tune up?
www.atlanticbritish.com, check out their tech tips.
Old Sep 12, 2008 | 09:28 AM
okdiscoguy's Avatar
What kind of air filter do you have? Also, look for a box under the passenger side seat and see if you have any numbers displayed on the LED screen...
Old Sep 12, 2008 | 10:09 AM
roverwoody's Avatar
The air filter isn't a k&n. Regular a guess. What does the fuel temp sensor do?
Old Sep 12, 2008 | 10:11 AM
roverwoody's Avatar
How do you read the display under the seat?
Old Sep 12, 2008 | 10:20 AM
Did you read the tech section on atlanticbritish.com?
The fuel temp sensor tells the ECUwhat the temp of the fuel going to the engine is. When these go bad they can cause "hot run" problems.
Old Sep 12, 2008 | 10:51 AM
What about your fuel filter, when was it last changed? Might also want to replace your fuel pump relay, common problem.
Start running high octane or you will carbon up that engine and possibly do valve damage, on the good side, you will get about 2 more MPG and better performance.
Let me know if you can't find how to read the codes and I will send you a link.
Old Sep 20, 2008 | 03:43 AM
tacomatech's Avatar
Check fuel pressure and make sure you have stock cap, rotor, plugs, and wires. I have seen fuel pumps slowly go bad, as well as aftermarket ignition parts cause no-starts and the like, just like you are describing.
-Kyle
Double J
Dec 27, 2009 03:32 PM
herblatham
Dec 27, 2009 12:36 PM
Double J
Dec 14, 2009 08:06 PM
shelleyman
Sep 14, 2008 07:38 PM
allen
Jun 29, 2007 08:42 AM
