LRT-19-009, Fuel Pump Replacement
Old Aug 5, 2009 | 08:44 AM
robdis96's Avatar
Default LRT-19-009, Fuel Pump Replacement
Just going through the manual on replacing the fuel pump and noticed the step for using an actual tool from land rover for the lock ring. Is this tool a must or will a similar tool/device work. Thanks
Old Aug 5, 2009 | 08:47 AM
You can pull the pump without it. What is wrong with yours?
Old Aug 5, 2009 | 08:52 AM
robdis96's Avatar
Thanks. Mine started leaking through the top connector. I posted some pics on a thread last week or so. Spike suggested sealing it and trying that first. I did and didn't keep it from leaking. Fuel seeps out of the top of the fuel pump when ever the truck is running. I have a used fuel pump headed this way now. Just wanted to check into the right steps and tools for the job.
Thanks
Old Aug 5, 2009 | 05:59 PM
Just use a big flat head screwdriver and a small hammer, tap gently yet firmly.
MarvelVT
Oct 23, 2019 08:09 AM
Travelor
Sep 24, 2015 06:11 PM
Dogfan
Apr 21, 2013 05:53 PM
JumPeR04
Apr 7, 2011 09:52 PM
03RRDude
Oct 26, 2009 07:18 PM
