LT230 + 2004 Shifter Problem Solved
Old Oct 16, 2007 | 03:56 PM
ajh's Avatar
ajh
Default LT230 + 2004 Shifter Problem Solved
So, the issue that wouldn't let me shift has been solved.
Some background. Bought a 2003 without knowing it didn't have a CDL, bought a LT230 off a 2001 and installed it, installed the 2004 cable actuated linkage from Expedition Exchange, could lock up but could not shift high-low.
Turns out that in 2001 the lockout solenoid is in the transfer case.
For 2004 the lockout solenoid is in the shifter lever.
For 2003 there is only one header on the harness to connect a lockout solenoid to.
When I found the 2nd solenoid connection (the dealer swapped cases for me as part of another deal so I had not seen the wiring) I put a 12v source on it and then voila I could shift. I did try to get the solenoid out of the transfer case but even after spending an hour and a half getting those bloody bolts holding the cap on out I could not free up the cap no matter what I tried. The proper fix is probably to remove the solenoid from the shifter, but for a temporary fix I'm going to splice together the two solenoid leads so that they both unlock. I've had the console on and off about 20 times this year and I'm a bit weary about doing it again right now.
We need a wiki with this kind of information.
Old Oct 16, 2007 | 04:19 PM
okdiscoguy's Avatar
Default RE: LT230 + 2004 Shifter Problem Solved
I think youARE the Wiki.....
Old Oct 16, 2007 | 07:45 PM
A Team's Avatar
Taking a shot in the dark here... Haveyou come across any info in regards to a LT 230 swap into a range rover classic. I have heard this has been done, however, I can't find a write-up about on the net.
The RR classic has viscous coupler in that is the biggest pile of sh#@ I have ever taken off road. Needless to say now it is totally locked up and I have my front drive shaft removed just so I can drive it until I can figure out what I need to do for the swap.
Sorry for the rant.
Old Oct 16, 2007 | 09:40 PM
ajh's Avatar
ajh
Yes, there are a few good pages on the Borg Warner to LT230 swap. I think you want a D1 case which is much easier to get since you need the mechanical speedo. Just google for Borg Warner to LT230 and you'll get tons of hits.
So splicing the two solenoid leads together has both working as expected. Yay.
Old Oct 17, 2007 | 11:08 AM
A Team's Avatar
Thanks!
Old Aug 24, 2015 | 11:19 PM
Charlie_V's Avatar
That's good info. Thanks for posting.
Old Aug 25, 2015 | 07:43 AM
cappedup's Avatar
This is like Back to The Future.
8 years ago thread. How do you find these?
coors
Sep 17, 2017 08:56 AM
Karl Freund
Jun 22, 2012 05:24 PM
Princess
Sep 6, 2011 09:14 PM
rgbeard
Aug 3, 2010 05:46 PM
kma32254
May 28, 2009 12:00 AM
