Lucky 8 propshaft vibration.
#41
Too kind Charlie V!
Now I'm onto replacing the front O2 sensors to see if that settles the motor a little. I can see the values are all over the place.
But doing the rears sucked so much — I don't wanna...
Anyone with a line on cheap bosch units? Best I'm getting is Rock Auto at just under $70 Canadian.
#43
I had them in my Amazon cart, then checked Advance, and they were in stock at local store, so I put it off. Then found a full set(downstream and upstream) on Ebay for 120.00 shipped. So I went ahead and purchased them. The seller had purchased them, then sold his Disco. They came in brand new in original boxes. I was not getting any codes, but when I watched the data stream of the O2 sensors, they were not cycling like I read they should be. They would hang on rich for 5+ minutes or longer, and sometime they would read 0.0 volts for a long time. I changed them yesterday and now they are cycling up and down, and the truck idles smooth, accelerates smooth.
#44
hazletbassist89
ROAMING WITH FRIENDS
21
10-14-2009 08:15 AM
dombam
10-28-2008 08:22 AM
