M & S in 3rd keeps blinking 04 d2
Old Aug 17, 2013 | 08:27 PM
moorebl's Avatar
Default M & S in 3rd keeps blinking 04 d2
when I select 3 on my disco 2 2004 I get a blinking m &s lights. wont go away til I put in neutral or drive turn the truck off then back on again. sometimes it takes a couple tries to get it off running through the box then off and back on again. when they blink the truck goes just reves no movement. upon normal operation when I turn the truck on and select d its fine. I can push the mode button and the s will light up. push it again and it goes off. where do I start on this issue. thanks
Old Aug 17, 2013 | 08:52 PM
If check engine light is not coming on, for other stored codes, then according to the RAVE shop manual you have the tranny computer detecting less than 9 volts on the power connections. Look at weak battery, bad connection, expecially on the black cable from negative battery terminal that bonds to chassis in a few places.
DavidG
Dec 9, 2016 03:34 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
rick.scott
Jul 4, 2009 12:01 PM
dikubec
Jul 28, 2006 05:22 PM
