M and S lights flashing .. Trans Pin lights
bear w me guys , this is a banger ,,
Park - LIGHTS
Reverse - LIGHTS
Neutral - LIGHTS
D - nothing
D3 - nothing
D2 - nothing
D1 - nothing
Driving makes M and S lights flash .. codes are P1843 cam timeout monitoring P0705 switch monitoring. Old battery failed .. Shell guy said connector not tight enough ...he put a screw in the + battery post .. the connector is damaged .... a new battery was put in .. a Varta 12V.. G8 ... I never seen this battey before .. positive is on left side .. had ot turn it around to connect it ..
M and S lights flashing same time
Park - LIGHTS
Reverse - LIGHTS
Neutral - LIGHTS
D - nothing
D3 - nothing
D2 - nothing
D1 - nothing
changed battery from this to that .. twisted the black cable in .. tried to put on a video .. but it says MP4 not allowed ..
The Drive light is flashing .. M and S lights are flashing .. I'm getting a am timeout monitoring P0705 switch monitoring code .. it's 28 degrees here .. not sure if that matters .. anyone know if it's not grounded ?hope thats it
