Back up lights O M G
Old Jan 14, 2023 | 12:55 PM
MAPC's Avatar
Default Back up lights O M G
I know that this has been stated in other threads but WOW---I cannot believe how bad the factory backup lights are.....they are at the 'why bother' level!
Can't believe that this passed government requirements.
www.powerfuluk.com here I come......
Popular Reply
Jan 16, 2023, 06:37 AM
miran's Avatar
miran
As Powerfull team did not export to EU I had to find different solution for reversing lights. And I did (redneck way)! Just for couple of $ and an afternoon of very slow labour.
This solution is not suitable for all rims.
Miran
Old Jan 14, 2023 | 01:13 PM
SilverSFR's Avatar
I would be willing to bet that the design of our backup lights is a government requirement thing. We dont want to make people think that our backup lights are actual on coming head lights. Or something like that.
I know that my Red Brake lights are sure bright and noticeable.
Old Jan 14, 2023 | 01:14 PM
MAPC's Avatar
I have owned a LOT of cars and have never seen anything this dim.
Old Jan 14, 2023 | 01:15 PM
wcc18999's Avatar
I agree that the back up lights are pathetic in the Defender. I got mine ordered from powerfuluk and they are late already. Supposed to have received them two days ago via DHL. Oh well...waiting a couple more days won't hurt.
Old Jan 14, 2023 | 01:34 PM
Jiman01's Avatar
The Powerful UK lights are a huge improvement. Two tips I’d give if you’re going to follow his video:
1- Solder at the bench vs. at the vehicle. I mounted the light(s) to the plastic panel off the vehicle, then wired, soldered, heat shrinked, and taped before mounting on the vehicle. IMO, much easier that way.
2- I found that making all the connections to the vehicle and then tucking the wires + getting the one 2-pronged wire holder thing remounted was a PIA. Instead make the 2-prong holder connection first, mount it, and then connect the other adapter. I found it to be less fiddly because there’s less wires in the way if you do it one at a time.
3- One additional tip if you have PPF, is to use painters tape to protect the film, edges, and panel as you pull them off. Actually I think it’s a good idea even if you don’t have PPF. Those suckers were on there super tight and even a “non-marring” tool could damage the paint if you keep prying at the same spot. Be patient and careful but as someone here posted a while ago, you got to ultimately pull on them like it’s not your car😂
Took abt an hour and taking the panels off was the hardest part cause I didn’t want to dork up the panels on my less than 3wk old truck😜
Old Jan 14, 2023 | 02:23 PM
D-Fens's Avatar
Mine came especially fast, but I heard something about intermittent postal strikes in the UK, so that might be what's holding things up for you. Hope they arrive soon! I need to find time to install mine.
Old Jan 14, 2023 | 02:58 PM
wcc18999's Avatar
Thanks for the tips. Will definitely pay attention. Cheers!
Old Jan 15, 2023 | 06:53 AM
Mike_F's Avatar
I installed my Powerful UK backup lights yesterday. I agree with Jiman01‘s tips.
Hearing the plastic clips crack was terrifying but in the end nothing major broke. I did lose three of the little plastic clips, but the PUK kit comes with four extras so I was all set.
One other wrinkle - my (US spec) 110S P300 has some kind of sensor attached via a short wire to the left/driver’s side panel that I didn’t want to remove. As a result I had to bring a step stool over to rest that panel on so it wasn’t dangling and in the way as I worked on the rest of the steps for that side. Nothing similar on the right - that one simply came off and I set it aside.
Good luck!
Old Jan 15, 2023 | 09:25 AM
Jiman01's Avatar
That’s interesting. I didn’t have any extra plugs on my MY23 D110X.
Old Jan 15, 2023 | 09:39 AM
Mike_F's Avatar
I should have taken a picture, but I'm not about to wrestle the thing off again just for a photo.
It was odd - it kind of looked like a light - a thin, square thing on the back side of the plastic. But it wasn't over an open hole - it was stuck directly to the back side of the plastic panel itself. No opening to emit light or allow anything to enter. Makes me wonder if it's a radar/parking sensor thing?
I tried to find the part on line, but no luck. Closest I could come is this:
https://parts.jaguarlandroverclassic...de=33C010315AC
Part number: <024A36 on the illustration.
Except the highlighted one in the illustration is the passenger side (in the US), and the one that had the mystery wire is the driver's side.
