M and S lights flashing .. Trans Pin lights
Old Dec 19, 2023 | 12:23 PM
protonmailrover's Avatar
Default M and S lights flashing .. Trans Pin lights
bear w me guys , this is a banger ,,
Park - LIGHTS
Reverse - LIGHTS
Neutral - LIGHTS
D - nothing
D3 - nothing
D2 - nothing
D1 - nothing
Driving makes M and S lights flash .. codes are P1843 cam timeout monitoring P0705 switch monitoring. Old battery failed .. Shell guy said connector not tight enough ...he put a screw in the + battery post .. the connector is damaged .... a new battery was put in .. a Varta 12V.. G8 ... I never seen this battey before .. positive is on left side .. had ot turn it around to connect it ..
M and S lights flashing same time
Old Dec 19, 2023 | 02:14 PM
ahab's Avatar
Not sure why D and below aren't lighting but a less-than-full battery will flash the M&S lights.
Old Dec 20, 2023 | 10:09 AM
changed battery from this to that .. twisted the black cable in .. tried to put on a video .. but it says MP4 not allowed ..
The Drive light is flashing .. M and S lights are flashing .. I'm getting a am timeout monitoring P0705 switch monitoring code .. it's 28 degrees here .. not sure if that matters .. anyone know if it's not grounded ?hope thats it
Old Dec 20, 2023 | 10:29 AM
ahab's Avatar
The battery still may not be 100% charged, despite being new. I'd throw a charger on it for a few hours and try it again.
Old Jan 18, 2024 | 12:41 PM
Charbelkhoury's Avatar
Default M S flashlight
Click and not start engine discovery 2
MAPC
Dec 18, 2023 10:31 AM
Ditzy456
Jul 13, 2021 12:18 AM
04duxlr
Dec 6, 2015 08:37 PM
marks500
Jan 27, 2010 09:57 AM
