M+S Lights....Help!
Old Nov 3, 2009 | 07:41 PM
rekogniz1's Avatar
Default M+S Lights....Help!
Ok! I have read every post regarding this, but non seem to have the same issue I an having.
1. Only get the M+S lights flashing in R and N
2. Can shift to D without stopping in R or N with no problem
3. If realy cold I can somtime use R without the lights coming on and flashing
4. After reversing and lights flashing I can reset by turning ignition of and if I go straight to D I am good to go
5. This is driving me nuts that I have to stop and shut off the ignition every time after reversing just so I can shift to D without the lights flashing
This does trip the Service Engine Soon Lamp. If I get three sucessfull shifts from Drive to Reverse it will go off until the M+S lights flash again.
Old Nov 3, 2009 | 07:49 PM
You need to go and have your battery and alternator tested, one of them is failing.
Old Nov 3, 2009 | 08:04 PM
rekogniz1's Avatar
Would the battery or alt cause it to only do it in R and N? Or would it be a switch?
Old Nov 3, 2009 | 09:03 PM
It could be the XYZ (yes that is its actual name) switch, but start with the simple/free stuff first.
Old Nov 3, 2009 | 09:21 PM
meltdowndave's Avatar
Just had this happen over the course of a year until my truck finally went into limp home mode and stayed there.
Although your symptoms are just like mine, do as Spike said and get the battery/alternator checked at Advance or the like.
If they test good, try the XYZ switch. They're $80 or so used from Roverland parts and $200 new from Atlantic British.
They aren't too tough to swap out.
Old Nov 4, 2009 | 09:14 AM
"ditto"!!
Old Nov 5, 2009 | 12:19 PM
rekogniz1's Avatar
Disco Mike- I see that you are local here in Denver! When is the BYOB Tech Day at your house?
Doral300sc
Feb 6, 2010 03:59 PM
USMC_Denver
May 8, 2009 12:41 PM
designedfree4u
Feb 24, 2009 06:33 PM
klh113
Dec 17, 2007 02:13 PM
tonyzp007
Jan 26, 2007 11:21 PM
