m s and service engine soon lights on
My green m s lights, red shifter light and service engine soon light came on the other day but yesterday they did not come on after a 100 mile trip. Today they came on after a short trip. They did not come on on the trip back home. The transmission was serviced 10k miles ago, the xyz switch was replaced two years ago, the battery was replace 3 months ago, and today I checked the battery and alternator and both checked out fine. The battery was at 13.4 with the engine at idle. I don't know what could be causing my lights to come on. Any suggestions will be greatly appreciated.
It can mean that the transmission ECU is low on voltage as it is the last one to get power from the wiring harness as I understand it. I just got dont welding on my Rover disconnected the negative cable overnight. Welded hooked it back up. M&S light flashing. Turned it off and they have not come back.
Check your negative and positive battery cable. Make sure there is a good connection. Make sure the clamp on the battery post is not bottomed out, so you cannot wiggle them by hand when fully tightend down. If you can turn by hand, your battery may not be getting fully charged by your alternator. This was my problem last Winter. I needed those lead caps that go over your battery post.
This may not solve your problem but I thought I would throw it out there.
