M & S warning lights on together Dicso II
Old Feb 2, 2007 | 10:41 PM
RAMJET's Avatar
Default M & S warning lights on together Dicso II
Help anyone, The disco's been sitting in the shed for a few weeks, and the battery's down a bit, so I hooked the jumper leads from the other car and let the charge build in the disco before starting, but the M & S warning lights have come on and I only have DRIVE (auto), hand book mentions electrical fault in the auto, but I thinking maybe a reset or fuse ??
Old Feb 3, 2007 | 11:28 AM
Default RE: M & S warning lights on together Dicso II
Most likely you are getting a low voltage fault code from the trannys ECU. Go replace your battery then take it to a tranny shop and have then read and clear the codes before it puts you into limp mode and you can't drive it.
Mike
cipher982
Nov 9, 2019 11:22 AM
whurst79
Sep 14, 2008 02:37 PM
groundpounder
Oct 6, 2007 08:14 AM
1eyescooter
Tires
Sep 27, 2006 04:25 AM
mikemeyer0
May 9, 2005 01:54 AM
