Possible firewall leak in 98 dicso
Old Sep 11, 2008 | 02:09 PM
whurst79's Avatar
Default Possible firewall leak in 98 dicso
I think I may have a leak in the firewall in my 98 disco, I thought it was the AC compressor dripping to much but now it seems to be strongly coorelated to heavy rainstorms. There was a wire from an amplifier from the previous owner that I believe goes through the firewall. It seems like the water comes up through the passenger seat floor and flows to the rear on that side. Any thoughts?
Old Sep 11, 2008 | 03:06 PM
okdiscoguy's Avatar
Default RE: Possible firewall leak in 98 dicso
Check you a/c drains for clogs, then look for holes in the fire wall. I am still willing t bet it is your drains. raining=more condensation=more water from a/c
Old Sep 11, 2008 | 03:33 PM
D1's were known to crack the welds where the bulkhead is welded to the floor, might want to have someone who experienced with this inspect it.
Crawl under the truck and look around the bell housing (where the transmission mates with the engine) and look for two rubber drain tubes. They should have nipples on them, squeeze the nips and drain the water.
Take a pipe cleaner and ream the tubes out to remove any dirt.
Old Sep 14, 2008 | 02:21 PM
whurst79's Avatar
Is the ac drain the same thing that spike described?
Old Sep 14, 2008 | 02:37 PM
Yes, those are the A/C drain tubes. I would start there.
Enigma753
Oct 13, 2012 12:05 AM
gusbone
Oct 7, 2012 09:10 AM
matt3502
Nov 12, 2010 01:29 PM
1eyescooter
Tires
Sep 27, 2006 04:25 AM
mikemeyer0
May 9, 2005 01:54 AM
