MAF from hell ...
Old Nov 17, 2014 | 06:44 PM
davecason's Avatar
Default New codes
Hi!
So I got two codes out of it while driving on Friday ......
P 1414
and also a
P 1417
So I read them and cleared them right away and all happy since then
but I haven't had a chance to actually check fuse F2 yet ....
Cheers'
Dave
Old Nov 17, 2014 | 06:46 PM
davecason's Avatar
Default two more codes
Hi!
P 1414
and also a
P 1417
Cheers'
Dave
Old Nov 20, 2014 | 06:12 PM
davecason's Avatar
Exclamation the mystery deepens
Yep,
I own a temperature sensitive Disco ..... this week it was -10 to -17 and no real problems. One day I had one P1174 and P1175 and did a reset and all good.
Today got in drive home +10 one hic-up (vehicle stalls and jumps) got to the store, parked, went inside for half an hour, came out and restarted and it won't start I had to ride the gas to get it going and keep it running- if not the RPM went down to under 300 and stalled. MOre hi-ups on the way home too .....
Ran the scan tool and I got 6 again .... P1184 - P0102 - P1412 - P1415 - P1175 and last P1172.
So yep, Dusty's right .... it IS temperature sensitive if its nice out it runs like sh*t if cold - happy as hell so what should I be looking for folks?
Cheers'
Dave
Old Nov 21, 2014 | 03:51 PM
davecason's Avatar
Talking All good !?!
HI,
So I cracked the hood today and checked and reset every relay
and fuse under the hood and also visually checked each little fuse
and put a DVM on each side of each fuse as well ..... all had 14.4
volts DC with the truck running.
Fuse 7 and 8 with have RTFM on the fuse cover had no voltage on
both sides of them but I don't think that's relevant because in my
RAVE manual it says they're for: #7 the front heated windshield and
#8 for the same thing but the other side.
So, I guess now what ?
Todays codes were:
P1175
P0102
P1884
P1172
P1412
P1415
In that order and of course I just did a reset again so we'll see.
I checked under driver side and most of them were coming up
hot at 14.x VDC and they all got pulled, looked at, and re-seated
too !
Again, I'm open to suggestions.......
Cheers'
Dave
landroverhell
Jan 29, 2009 01:25 PM
Chillbilly
Jul 9, 2008 07:34 PM
ather90
Apr 7, 2008 02:18 PM
ajh
Sep 29, 2007 06:21 PM
jpattoncook
May 8, 2005 08:59 PM
