MAF or O2 sensor codes
Old Apr 11, 2011 | 09:27 PM
DonRW2007's Avatar
Default MAF or O2 sensor codes
Hi. 99 Disco w/ 96k miles. Getting intermittent P1172 and 1175 codes - looks like O2 sensor or MAF issues from forums, with most posts suggesting MAF. Question - I recently replaced air filter. Could jostling around with air box and manifold have created a mechanical problem with MAF sensor? Anything I can check before replacing?
Thanks!
Old Apr 11, 2011 | 09:46 PM
jafir's Avatar
What part, like brand or type, did you use to replace the filter?
Old Apr 12, 2011 | 08:54 PM
DonRW2007's Avatar
Bought it from Atlantic British - supposedly OEM - I think it was Bosch (or Fram)? At any rate, seemed to be standard filter. I've seen some additional posts about leaks or holes in intake; haven't had a chance to inspect. At ~$150, I think it's relatively cheap insurance to replace MAF sensor, but again, no use doing so if it's not a problem. Is this something that is typically replaced in a truck with mileage similar to mine (95k miles)?
KlamathMatt
Apr 17, 2020 05:27 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
StevenDiscoII
Mar 18, 2012 04:54 PM
BajaXJ92
Dec 3, 2009 07:43 PM
