MAF sensor
Old Oct 3, 2012 | 10:27 AM
First, there are 2 sensors inside our MAF, not one.
The difference between the 99 to 02 MAF and the 03-04 is the size of the barrel, the 03-04 have a slightly larger intake.
Old Oct 3, 2012 | 11:12 AM
jafir's Avatar
Yes, but it's one "part" the two sensors are integrated. I've had mine apart and the numbers on the 99 are the same as the numbers on the 03.
Old Oct 3, 2012 | 03:59 PM
bigcraigman's Avatar
On the CRC video I watched on you tube they removed the MAF and soaked it down. I used half a can at least on mine, then let it dry for about an hour which was probably longer than necessary.
Old Feb 19, 2013 | 11:08 AM
keithatcpt's Avatar
3rd Gear
Just installed a new Bosch 0280217532 MAF in my Discovery 2 from Partsgeek - Paid $125.25. Ground shipping was free to NH.
Old Feb 19, 2013 | 11:14 AM
Year of the D2? And did it make things better?
Old Feb 19, 2013 | 02:33 PM
clanch's Avatar
Bosch # 0-280-217-532 is the factory number. Air mass meters are only good for 100k or ten plus years. You can replace both your front 02 sensors, and the next day trip a air mass meter fault. Old meter cannot keep up with new 02 sensors. Air mass meters are a consumable part like spark plugs.
Old Feb 21, 2013 | 07:45 AM
keithatcpt's Avatar
3rd Gear
Had a Service Engine light pop up a couple of weeks ago, threw a code that the MAF circuit was low. Engine ran worse, stumbling at idle and at light throttle. My D2 has 174k miles, so it was pretty obvious the MAF had failed. I researched a lot of posts, found one post somewhere that said Partsgeek had OEM Bosch MAF's. I installed it in less than 5 minutes, cleared the code with my code reader and right away I knew the problem was better; runs smooth, starts well. No stumbling and most important, after two days no Service Engine light.
KlamathMatt
Apr 17, 2020 05:27 AM
pilsner
Aug 6, 2008 10:20 PM
vjm530
Jul 16, 2008 03:40 PM
vjm530
Jul 7, 2008 08:19 PM
Different Drummer
Oct 1, 2006 07:03 PM
