MAF sensor bad, multiple DTC codes
Have not visited for couple years. My 2000 Disco II now has 153k miles. Couple months ago I have done Seafoam treatment, the most common via brake booster vacuum port on the intake manifold. After that I had check engine light come on. My code reader displayed following codes:
P1884 CAN Message - Certain Inputs / Outputs Out Of Range
P0102 Mass Air Flow Sensor Faulty, Drive Cycle A - Signal Out Of Range / Below Minimum
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P1590 ABS rough road signal circuit malfunction
P0130 O2 Circuit (Bank 1, Sensor 1)
I have reset the codes couple of times, however, all came back again.
Since I had a spare MAF sensor since about 2008 (OEM Land Rover) I figured I start with that. After replacement I have cleared the codes again and bingo. All DTC's cleared and have not reappeared again. Only P1590 is showing a unresolved issue, however, this does not trigger check engine light.
Just wanted to post this if it may someone with their MAF sensor issues diagnostics.
I have no clue regarding timing of this problem in association with the seafoam treatment, perhaps someone else have experienced similar problems. Could I have done something wrong? Maybe administering the seafoam too fast?
