..:: The Magic Bolt ::..
Old Nov 15, 2016 | 09:58 PM
Charlie_V's Avatar
Originally Posted by adolfojbonilla
...well, I haven't confirmed that yet, but the shrine it's on, right next to to that pipe that gave me hell to pull out! ;-]#
I had a magic bolt jump from my motor mount to a cylinder when I was rebuilding my engine. Yours seems much better behaved.
Old Mar 25, 2017 | 03:48 PM
adolfojbonilla's Avatar
Hello Roverers!
Remember that "mysterious bolt" that appeared on top the radiator cowl? ...well, just found out where it came from ...luckily!
For a while I've been listening to a high pitch noise, apparently from some front engine bearing, but never got a chance to figure it out, until today, while solving a 0308 issue ...I had to take out the plastic cover that protects the Compressor and one of the expander tubes fell off, so I had to take the radiator cowl out to get it... when I saw a hole in the middle of the Compressor, I jiggled the whole piece and clearly was loose, so I figured the bolt had to be the one to hold in place. Screwed it in ... and it fits like a glove ...so if it fits, it must be guilty! ...got it in, tightened it till the whole things spins, hopefully it will tighten more as it turns, otherwise I don't know how to tighten it even more.
So mystery solved, hopefully the turbine-like noise will go away.
Now back to the other issues! ;-]#
Here some pics!
Old Jun 10, 2017 | 12:18 PM
Hi Guys! ...anyone knows the specs of that bolt? just saw this morning that it was missing again, but didn't have the luck of finding it laying around. Help will be very much appreciated!
Old Jun 10, 2017 | 02:23 PM
CollieRover's Avatar
do you have a dealership close? They may have one, could get one, or at the least let you know what size of bolt it is.
Old Jun 10, 2017 | 04:34 PM
OverRover's Avatar
IDK bolt size, but it's in this kit > A/C Compressor Clutch Kit Repear fits Land Rover Discovery Range Rover Defender
PLEASE....... Loctite that Ba$tard the next time.
Old Jun 10, 2017 | 06:10 PM
...thanks CollieRover, but don't have a dealership nearby, although did a good search in the Forum and found the specs for the sucker! M6 x 20mm ;-]#
Old Jun 10, 2017 | 06:17 PM
Thanks OverRover, but found the specs for it, is a 6M x 20mm Screw-Flange Hex bolt. A friend that works with home A/C recommended to put a Split-Lock washer as well, so I did, and yes, did put some "medium strength" thread locker on the sucker, and tightened it as hard as I could; no easy way to hold the thing without turning, but I think I tightened it enough. Thankfully truck is inside the garage, so will let it sit overnight and fire it up tomorrow, just for the thread locker to harden as it should. ;-]#
Old Jun 10, 2017 | 07:37 PM
nice work!
Old Jun 10, 2017 | 08:58 PM
JUKE179r's Avatar
If you have a Fastenal store near you, they would be the best place to get that bolt.
https://www.fastenal.com
They are my go to hardware store for bolts, nylocks and washers for my Disco.
Old Jun 10, 2017 | 09:39 PM
...thanks JUKE179r for the tip, although I did get them from Advance Auto parts (spent no more than $4.30), but already searched for a FASTENAL store around here, and found one within the same distance of the AAP store, so will keep it in mind, thanks! ;-]#
RenoHuskerDu
Oct 12, 2011 07:01 AM
Spencerfitch
Mar 24, 2011 08:14 AM
sleepy740
Detailing
Jul 13, 2009 06:49 PM
Jst4fun
Oct 11, 2007 09:38 PM
