Magnecor wires
Old Jul 11, 2010 | 01:35 PM
2003landroverdiscovery's Avatar
Default Magnecor wires
I actually have a couple of quick questions, so far everyone on here is incredible.
For my 2003 Discovery do I need Magnecor 7mm or 8mm wires.
I keep hearing about a Rave book that I must get can anyone tell me which one it is and where
and last but not least, I can do minor repairs, but Im needing to fix the three Amigos, change my wires cause the ones I have are crap, and replace my throttle body gasket are these three things a very new beginning novice can do. I have read all the step by step instructions on here and directions, are they for a novice to do.
Any help would be greatly appreciated.
1 more, plugs were changed 5 mos ago, along with the wires but the wires are very cheap ones and thats why im having problems, whould i just go an do the plugs to or are any plugs ok
Old Jul 11, 2010 | 01:40 PM
lipadj46's Avatar
Plug are fine. Get the magnecor 8mm wires or kinsborne or STI 8mm wires. Sure those are easy DIY but the 3 amigos will require an abs scanner. I think discomike as a link to the rave cd in his sig.
Old Jul 11, 2010 | 01:47 PM
Do a search for the RAVE, it is a electronic copy of the hard cover workshop manual.
Lots of guys have a link in their sig, just be warned it is big because it covers everything.
7mm is stock size plug wire, 8mm is what is preferred.
I dont think 1mm will get you any more of anything but for a extra $5 what the hell.
Old Jul 11, 2010 | 04:33 PM
d2luvr's Avatar
rave link is in my sig.
Old Jul 11, 2010 | 06:53 PM
hilltoppersx's Avatar
get the 8mm. loads of D2 owners have misfires with 7mm wires because of the excellent heat disepation that our aluminum blocks have.
Old Jul 11, 2010 | 09:16 PM
What will I need an abs scanner for, with the three amigos. Im lost there
Old Jul 12, 2010 | 08:47 AM
DarylJ's Avatar
To read the codes and clear them.
Reading the codes (which can only be done with a scanner that reads the ABS codes of a Discovery - so it's either a $200 ABS Amigo for just that purpose or a $3000+ scanner with the right software) which indicates where to start on repairs, and then to clear the codes.
Even if you did repair the problem without pulling the codes, you still need to clear them to get the lights to go out.
Old Jul 12, 2010 | 10:16 AM
Ok, I've already had the codes read at the dealer, and they tell me that I need a new ABS Module, all three lights come on at any time, they seem to reset sometimes when I shut it off but they keep coming back. I can do the repair, then what your saying I need to bring it back to get everything clear by their scanner again to get the lights off for good.
Please excuse me for asking the questions, I'm still learning.
Old Jul 12, 2010 | 11:25 AM
mwindth's Avatar
I would perform this fix before sinking money into a new ABS Modulator:
https://landroverforums.com/forum/sh...ad.php?t=26847
Also, re-build your front u-joints if you have not done that yet:
https://landroverforums.com/forum/sh...ad.php?t=29302
These and many others are in the "Write ups" and "How To" sticky at the top of the page.
Old Jul 12, 2010 | 12:29 PM
Bundu's Avatar
Banned
The dealer would just love to sell you a $2000+ ABS modulator.
