Maintenance on idler pulleys help with p #
Old Jul 6, 2019 | 08:53 PM
redwhitekat's Avatar
Default Maintenance on idler pulleys help with p #
Just as a pm I ordered a new tensioner and one idler pulley however the smaller idler pulley I think it’s a 70 mm right under the tensioner is a bit tight and doesn’t spin freely
can anyone confirm if Dayco 89052 is the correct part number for this pulley ?
So so far all the parts supplier around me don’t even list a disco idler pulley
Old Jul 7, 2019 | 09:46 AM
Just looking for the 70 mm pulley
Old Jul 7, 2019 | 08:23 PM
Found a local parts supplier that can order one. Carquest was the only supplier that even listed the pulleys.
Old Jul 8, 2019 | 02:08 AM
JUKE179r's Avatar
This is what I have on my D2 parts cheat sheet for the pulley:
  • Small idler pulley: 70mm Dayco #89052 steel (Double seal bearing, 17mm x 40mm x 12mm - #6203-2RS); NTN & SKF are two good brands; same bearing for alternator
Old Jul 8, 2019 | 10:19 AM
the 89052 is the 80 mm. According to parts source here in Canada. They brought the box out and it was 89052 but it was indeed the 80 mm. I had the 70 mm in my hand to proper verify
Old Jul 8, 2019 | 10:23 AM
Best4x4's Avatar
I looked it up in my cheat sheet as well and I have an Auto Zone P/N 231052. It fits a variety of vehicles & the specs list it as a 70mm pulley by 30mm wide.
Old Jul 8, 2019 | 10:59 AM
Thanks
Old Jul 8, 2019 | 11:04 AM
Best4x4's Avatar
No problem!
Old Jul 8, 2019 | 05:24 PM
Picked one up today from a local supplier. Diameter is the same but the bolt hole is way bigger. Dammm might have to order online
Old Jul 9, 2019 | 08:22 PM
Best4x4's Avatar
Are you sure you aren’t missing the collar the pulley sits on?? When you remove the OEM 70MM pulley it’s a 13mm bolt with a curved washer on the front, then at the back it should have a tiny O-Ring keeping the bolt in place. If you remove the O-Ring you will find the rear spacer/collar piece. That is what the Auto Zone 231052 Pulley sits on. That should fit perfectly, then re-install the bolt, front washer, rear spacer/collar, and the O-Ring (just there to keep it all together nicely), then tighten the 13mm bolt down.
I actually just did this job on my 02 Kalahari this evening. The Auto Zone 231052 = perfect fit & no issues. Was like 16.00 out the door. When I drove the Kalahari over the weekend it was squeaking just a tiny bit so I replaced it.
