Major Brake Problem!
Old Feb 9, 2009 | 10:23 PM
lostsheep22's Avatar
Default Major Brake Problem!
I have a 96 Disco w/ 130k. I lost my brakes so I replaced the master cylinder. I couldn"t get it to bleed out so I took it to the Land Rover Mechanic. He couldn't either, said it was a bad Master cylinder. So, I sent off for another one. Put it on tonight, same problem. Can't get the air out of the front driver caliper. Using Castrol GT LMA fluid. I can't believe that I would have 3 bad Master Cylinders. Any thoughts or suggestion??? Please Help!!!
Thanks in Advance,
Kyle
Old Feb 10, 2009 | 01:11 AM
llPANCHOll's Avatar
Default RE: Major Brake Problem!
Is there a bleeder valve on the bottom of your Master Cylinder??
Old Feb 10, 2009 | 05:55 AM
AK Rover's Avatar
You're still sucking air in from somewhere (like you didn't already know that). Pull your master cylinder and check all the seals, paying close attention to any seals between the master cylinder and the fluid reservoir. Have you done any other work to the brake system? How are you going about trying to bleed the brake system?
Old Feb 10, 2009 | 01:19 PM
I've bench bled both new master cylinders. Installed it and started bleeding with the rear passenger tire, driver rear, passenger front and then driver front. The air seems to mainly be in the driver front. There are no leaks (that I nor my mechanic) can find.
The only thing I can think of is that air is entering through the ABS module somehow? Thoughts?
Kyle
Old Feb 10, 2009 | 02:02 PM
okdiscoguy's Avatar
Bench bleed it again and start with the driver's front. If the line is dry, you may be sucking air right back in. If you need to bleed the ABS, I am pretty sure if you turn the key on and hold the pedal to the floor for 30 seconds, the pump will cycle.
You are using DOT 4 fluid, right?
Old Feb 10, 2009 | 02:12 PM
OKdiscoguy,
My Rover mechanic said he bled the ABS by doing that very thing. Yes, I'm using the Castrol Dot 4 fluid. Any other suggestions? I can't wrap my brain around it.
Kyle
Old Feb 10, 2009 | 02:27 PM
okdiscoguy's Avatar
I say keep trying the one you think might be dry. I had a problem similar with an old Pontiac, and one line just had a lot of air that kept getting sucked back into it. I had to take it off and bleed it like 5 times.
Start with the driver's front. and work backwards, see if you get the same results.
Old Feb 13, 2009 | 09:35 PM
Mechanic replaced the ABS Module today. Still have the same problem. It's sucking air in from somewhere but it's not leaking anywhere. I'm stumped. Thoughts?
pizzaboy
Aug 13, 2012 09:57 AM
jbremser
Dec 26, 2008 03:07 PM
mandythelandy
Defender
Dec 26, 2008 04:33 AM
AJBoardman
Nov 19, 2008 09:41 AM
redrvr
Nov 6, 2006 03:15 PM
