major engine problem
Old Oct 12, 2006 | 05:25 PM
hoberock's Avatar
Default RE: major engine problem
Here are few suggestions for misfires:
-Faulty spark plug or wire
-Faulty coil (pack)
-Faulty oxygen sensor(s)
-Faulty fuel injector
-Burned exhaust valve
-Faulty catalytic converter(s)
-Running out of fuel
-Poor compression
-Defective computer
Since you have replaced the catalytic converter(s), that is not it. Since the happens on multiple cylinders, it is probably not the Fuel Injector(s) or Burned Exhaust Valves. I think I would check the following:
- Fuel Rail Pressure
- Cylinder Compression
If you can find a cheap used computer, you MAY try switching that out as well. Also, if you have a way to check the O2 sensor switching, that would be very helpful. My guess (and this is only a guess) is that your O2 sensors are going out...
Tim
Old Nov 5, 2006 | 11:31 PM
redrvr's Avatar
7th Gear
Thanks for the help to everyone
I replaced the MAF and it's now perfect!
Thanks again
Pat
Old Nov 6, 2006 | 03:15 PM
98roverguy's Avatar
Glad to hear!!
deepessions
Oct 8, 2009 12:21 PM
lostsheep22
Feb 13, 2009 09:35 PM
jbremser
Dec 26, 2008 03:07 PM
mandythelandy
Defender
Dec 26, 2008 04:33 AM
AJBoardman
Nov 19, 2008 09:41 AM
