Manifold to y-pipe gasket leaks
Old 09-16-2017 | 10:14 PM
Jwehking's Avatar
Default Manifold to y-pipe gasket leaks
I've replaced, tightened, retighten. Still leaks. The gasket is like two thin pieces of metal crimped together. Is there alternatives or how to fix leak?
Old 09-17-2017 | 03:44 PM
LR03NJ's Avatar
Default Try this one.
Try this one.
Works on mine really well. I forgot that my truck can sound quiet.
Old 09-17-2017 | 03:54 PM
LR03NJ's Avatar
Old 09-17-2017 | 03:58 PM
BackInA88's Avatar
Is the pipe flange parallel with the manifold mounting surface before you put the gasket in?
How are your motor mounts?
Old 09-17-2017 | 04:22 PM
Jwehking's Avatar
Best I can tell all is in good alignment. Very easy to line the pipe up and slips right on the studs. Maybe I need to drop the whole pipe and clean the surface?
Old 09-17-2017 | 04:46 PM
mln01's Avatar
Just thinking out loud - could you double-gasket this joint? Maybe that would address a larger than normal gap between the manifold and the Y-pipe.
Old 09-17-2017 | 05:03 PM
Friday Night Disco's Avatar
yes, clean it and don't tighten one side. Take your time and do patterns on the studs left and right side till it is in place. Then tighten all the way using a pattern
Old 09-17-2017 | 08:06 PM
Jwehking's Avatar
Yep, did that first time. Kept it all even while tightening. I hate exhaust work, usually never goes well
Spencerfitch
09-27-2020 12:17 PM
04duxlr
07-03-2013 11:02 AM
FlyingZebra34
04-22-2013 12:07 AM
discoboy
12-20-2012 02:24 AM
Chrisinhouston
12-23-2007 10:26 AM
Quick Reply: Manifold to y-pipe gasket leaks
