Manifold to y-pipe gasket leaks
Old Sep 16, 2017 | 10:14 PM
Jwehking's Avatar
Default Manifold to y-pipe gasket leaks
I've replaced, tightened, retighten. Still leaks. The gasket is like two thin pieces of metal crimped together. Is there alternatives or how to fix leak?
Old Sep 17, 2017 | 03:44 PM
LR03NJ's Avatar
Default Try this one.
Try this one.
Works on mine really well. I forgot that my truck can sound quiet.
Old Sep 17, 2017 | 03:54 PM
LR03NJ's Avatar
Or this one
LAND ROVER RANGE DISCOVERY EXHAUST PIPE TO MANIFOLD GASKET AND STUD AND NUT KIT | eBay
Old Sep 17, 2017 | 03:58 PM
BackInA88's Avatar
Is the pipe flange parallel with the manifold mounting surface before you put the gasket in?
How are your motor mounts?
Old Sep 17, 2017 | 04:22 PM
Jwehking's Avatar
Best I can tell all is in good alignment. Very easy to line the pipe up and slips right on the studs. Maybe I need to drop the whole pipe and clean the surface?
Old Sep 17, 2017 | 04:46 PM
mln01's Avatar
Just thinking out loud - could you double-gasket this joint? Maybe that would address a larger than normal gap between the manifold and the Y-pipe.
Old Sep 17, 2017 | 05:03 PM
Friday Night Disco's Avatar
yes, clean it and don't tighten one side. Take your time and do patterns on the studs left and right side till it is in place. Then tighten all the way using a pattern
Old Sep 17, 2017 | 08:06 PM
Jwehking's Avatar
Yep, did that first time. Kept it all even while tightening. I hate exhaust work, usually never goes well
Spencerfitch
Sep 27, 2020 12:17 PM
04duxlr
Jul 3, 2013 11:02 AM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
Chrisinhouston
Dec 23, 2007 10:26 AM
