Manifold to Y pipe gaskets failed after days
Old Apr 30, 2019 | 06:39 PM
Ben Matheson's Avatar
Default Manifold to Y pipe gaskets failed after days
I had the gaskets replaced but within a couple days noise was back. Jammed the leaf blower up the tailpipe and sprayed soapy water everywhere. Big time bubbles where manifold meets y pipe.
Is there a trick to getting a good permanent seal. Sucks to have to do this over again.
Old Apr 30, 2019 | 06:52 PM
Nosugar0carbs's Avatar
I’ve had many failures a few months after repair as well, I don’t know, maybe cats getting too hot and burning up the seal? I’m in FL as well, where you at Ben?
Old Apr 30, 2019 | 06:58 PM
Orlando
Old Apr 30, 2019 | 06:59 PM
Has anyone ever doubled up on the gaskets?
Old Apr 30, 2019 | 07:58 PM
Dave03S's Avatar
One thing I noticed when I had this done was that the shop put the new Y pipe on when the truck was not stone cold. I drove it to the shop probably 13 miles then it sat for maybe an hour and they did the Y pipe... This means that the bolts on the studs will tighten further when it is all the way cold, due to thermal expansion/contraction. Try tightening the bolts down before you drive it... Worked for me. Easiest done from underneath with an extension.
Old Apr 30, 2019 | 09:00 PM
I’ll try that on a next rebuild. I have thought about double gasket but then I was thinking”more surface area to blow”. Also thought about height temp silicon.
Old May 1, 2019 | 04:27 PM
The Deputy's Avatar
Double gasketed one of mine, worked fine. Usually, if l have the y-pipe off...l'll flat file the top of the flange, making it true again. And, l'll do the same to an exhaust manifold, if l have it off. They can get pretty wonky, from all of the heat cycles and old age. But yeah, doubling the gasket worked for me in one case.
Brian.
Old May 1, 2019 | 05:43 PM
Motorhead1's Avatar
I have a mechanic friend who swears by Permatex Copper Coat for manifold gaskets and head gaskets. I haven't tried yet. You may also have cracks on the y-pipe end, pretty common.
GreenRoving
Sep 5, 2019 01:25 PM
04duxlr
Jul 3, 2013 11:02 AM
FlyingZebra34
May 12, 2012 05:55 AM
DiscoIIBrandon
Aug 19, 2010 02:23 PM
Robwsup
Feb 16, 2010 05:06 PM
