Manual ignition timing reset
on
1 Post
ORIGINAL: tophur
dear friends,
thanks a lot for the info. in particular, S4Poor, what you wrote, shared, here:
dear friends,
I will say that there are many programs out there to adjust ECU settings via the OBD II. I use a program called Lemmi-Winks for my Audi, I can pull/add timing etc. with it. There has to be similar software for the Disco out there.
Best of luck.
okay, thanks very much.
In addition to this topic, we are looking for the negative / common wire to the injectors...
or, in other words, the injectors firing signal line.
Where can we find this? It's probably better that we can find the negative / common wite to the injectors?
a picture would be worth a thousand words in this case....
poked around for it and couldn't find it.
T
T
Go here and download a manual....
http://green-oval.com/joomla/index.p...me&dir=ASC
it's free and might save you some trouble. The injectors are on the fuel rail under the manifold. Yours has a different engine management system than mine...
Martin Rodriguez
02-25-2014 08:55 PM
Russian_Rover
11-26-2012 06:12 AM
