Manual ignition timing reset
Old Feb 6, 2008 | 07:57 AM
S4poor's Avatar
Default RE: Manual ignition timing reset
ORIGINAL: tophur
dear friends,
thanks a lot for the info. in particular, S4Poor, what you wrote, shared, here:
Not a problem, just a simple search, and cut & paste from Wikipedia ;-)
I will say that there are many programs out there to adjust ECU settings via the OBD II. I use a program called Lemmi-Winks for my Audi, I can pull/add timing etc. with it. There has to be similar software for the Disco out there.
Best of luck.
Old Feb 6, 2008 | 05:40 PM
tophur's Avatar
okay, thanks very much.
In addition to this topic, we are looking for the negative / common wire to the injectors...
or, in other words, the injectors firing signal line.
Where can we find this? It's probably better that we can find the negative / common wite to the injectors?
a picture would be worth a thousand words in this case....
poked around for it and couldn't find it.
T
Old Feb 6, 2008 | 07:19 PM
okdiscoguy's Avatar
Go here and download a manual....
http://green-oval.com/joomla/index.p...me&dir=ASC
it's free and might save you some trouble. The injectors are on the fuel rail under the manifold. Yours has a different engine management system than mine...
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
Russian_Rover
Nov 26, 2012 06:12 AM
tico21
Jan 25, 2008 11:58 PM
chelo
Mar 23, 2006 04:39 PM
