Manual and Sport Modes flashing
When I had that problem it ended being a weak battery and/or ground problem. Before I narrowed it down to the battery and battery ground connections, I could switch the key on and off a few times and it would clear the flashing M & S lights and do fine for awhile which made me think it was elsewhere.
If you start it, and it goes into limp mode with flashing M&S, try switching the key on and off a few times and see if, when you start it back up, the lights clear.... not a fix but may get you home without flashing M&S.
Try charging the battery and cleaning and tightening the battery terminals and all ground connections and see if it helps. If that fixes it for awhile (days to months depending on how much you drive) and then it comes back, then it is probably the battery or alternator. If that doesn't fix it then move on to xyz cleaning/replacing, etc.
Start with the easy stuff first.
Thanks for your all your tips,finally I found one of the 3 wires connected to the throttle is spoil and has been fixed. When it was fixed,the manual and sport mode light stopped flashing and my truck came back alive. Only issue now is my transmission light light that appear whenever I am on highway for a long time. Any tip on this is appreciated too.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
