manually locking the diff 00 disco
Old Mar 1, 2011 | 06:33 PM
grandkodiak's Avatar
Default manually locking the diff 00 disco
I'd like to get a conversion kit or maybe that electronic actuator kit for the locking diff, but in the meantime i understand it can be done manually under the car by turning a 10mm nut on top of the xfer case.
i was wondring, can it be turned farther in either direction for lock/not locked, and which direction is which? (clockwise/in/down or counter/out/up from the prespective of looking down from above the car with the front of the car facing up/north)
can you fit a socket and ratchet wrench up there, or must it be done blind with an open ended wrench?
i fear over turning it in either direction, or not being able to find lock/unlocked if they are specfic points and doing stupid damage by simple means of ignorance!
Old Mar 1, 2011 | 07:11 PM
mwindth's Avatar
Use a 10mm wrench...feel for the shift nipple on top of the transfer case and turn it clock wise and your CDL will be locked.
Old Mar 2, 2011 | 06:36 AM
ok so down into the xfer case locks... but how far do you turn it, a certain angle, certain number of complete turns, or until it stops? (and vice versa to unlock)
Old Mar 2, 2011 | 07:40 AM
Bundu's Avatar
Banned
Turn till it stops either way, it can only go so far.
Old Mar 2, 2011 | 08:33 AM
mwindth's Avatar
single ~45 degree clock wise turn...opposite to dis-engage.
Old Mar 2, 2011 | 04:11 PM
ok thank you!
Old Mar 2, 2011 | 04:25 PM
DiscoKline's Avatar
It has a detent, so you will feel it engage. At least mine does...
Old Mar 2, 2011 | 08:02 PM
coors's Avatar
Me too. You will hear the internal gears lock or go "click".
Old Mar 2, 2011 | 09:11 PM
ljdiscovery's Avatar
As I recall, you should also have a light come on the dash and I think the abs and a couple of the other lights come on when it is engaged. Phil
Fuddy
Nov 20, 2014 06:26 AM
aftermath431
Oct 17, 2013 01:45 PM
Dean
Oct 2, 2013 06:13 AM
johanba
Apr 3, 2007 11:37 AM
bookerbr
Feb 25, 2007 03:27 PM
