Mass Air Cleaning
No codes, just rough idle once in a while. Changed plugs and this did not help. Could be the IAC, but the air filter from previous owner was filthy, so I am assuming the wire needs to be cleaned. I see a mesh, which looks very dirty, but wonder if this is what I need to clean? Usually there are two wires in the mass air assembly to clean. I have some mass air cleaner but just want to make sure I am cleaning the sensor properly.
My rough idle was fixed by a good induction cleaning and changing out the O2 sensors...I threw a code for the sensor though. Just watch out for all the smoke you are going to get with the cleaning...I could barely see through mine.
bcolins
01-18-2015 11:40 AM
