Master Cylinder / Front Brakes -- which first?
All,
I need to replace the master cylinder, rotors, and pads for the front of my Discovery.
Is there a suggested order? I was thinking brakes, but not sure if one option would get less air in my lines than another.
Also - on the brake pads? Even with the shims that the manufacturer puts on the back, is everyone still suggesting sound deadening on back?
Thoughts??
Thanks
Matt
Thoughts??
Thanks
Matt
my brake fluid levels are fine, no leaks.
foot goes almost to the floor when i press the brakes. however, if i pump a few times the pressure is built back up to 'near normal'.
this would seem like a sign of a master cylinder.
my thought is i should do the front brakes first, so when compressing the caliper to put new pads in i dont send old fluid back into my new master cylinder. if i do brakes/pads, then master cylinder, then fluid change i am thinking that would be best.
any major reasons why i should do the master cylinder first??
thanks
matt
thanks
matt
97_Disco1
01-23-2011 09:29 AM
