Master Cylinder Leak?
Old Aug 1, 2022 | 10:10 PM
girlfriendboughtarover's Avatar
Default Master Cylinder Leak?
Hey all,
My master cylinder looks like it has corrosion from brake fluid on top. -- see photo -- I wonder if this looks like I should replace the cylinder. The area is not wet however. Brakes are somewhat spongy but I am going to bleed them again tomorrow to make sure no air in the system.
Old Aug 2, 2022 | 04:26 AM
mln01's Avatar
If there is no evidence of brake fluid leaking now I wouldn't worry about it.
The brake fluid level can be a little more difficult to see. Is it topped up in this truck? Be sure to use DOT 4 brake fluid.
Old Aug 2, 2022 | 01:30 PM
Richard Gallant's Avatar
Here is how I checked mine - leave it for a couple days if it is dry you are good. If not you have a problem
Old Aug 2, 2022 | 01:32 PM
Brilliant
Old Aug 2, 2022 | 02:09 PM
mln01's Avatar
Whoa. That's a little high tech for me. Does that diagnostic tool plug into the OBD II port, or is it self-powered with batteries?
jmac
Apr 21, 2022 06:41 PM
Colorado David
May 8, 2019 09:53 PM
discoken
Mar 7, 2014 03:29 PM
drdeadchef
Jun 10, 2012 10:10 AM
Shaymer
Nov 18, 2008 12:42 PM
