Matching OEM Keys...
We normally sell a matching set for $200 on eBay.
If I get one, I can include 2 fob cases with cut key blades that you put your remotes into.
that may work. only one key has the chipset inside it the other is only a blade. for the time being i swapped the "guts" into the other key so i have ignition key on the key chain but have the remotes to unlock the doors. ideally i would like to remedy this by having one key again that does it all.
..mg..
06-03-2016 08:19 AM
mpmiller1980
07-21-2009 06:30 PM
