Matching OEM Keys...
Old Jun 21, 2016 | 08:33 PM
iconoclast's Avatar
Default Matching OEM Keys...
I have an ignition switch which was replaced. Now there are two different keys. One for ignition, and one for doors. Is there a way to purchase an ignition which matches the other locks in the vehicle?
Old Jun 21, 2016 | 08:51 PM
abran's Avatar
I do not think it will be possible to buy an ignition that matches your handle.
We normally sell a matching set for $200 on eBay.
Old Jun 21, 2016 | 08:57 PM
iconoclast's Avatar
i am aiming to fully restore and recondition this vehicle but not sure it bothers me that much. if i go that route does it come with new keys, fob and ignition?
Old Jun 21, 2016 | 09:40 PM
abran's Avatar
I don't have a set right now. Normally the remotes are sold with the BECM, ECU, gauge cluster set as the remotes are coded to the BECM.
If I get one, I can include 2 fob cases with cut key blades that you put your remotes into.
Old Jun 22, 2016 | 06:53 AM
iconoclast's Avatar
that may work. only one key has the chipset inside it the other is only a blade. for the time being i swapped the "guts" into the other key so i have ignition key on the key chain but have the remotes to unlock the doors. ideally i would like to remedy this by having one key again that does it all.
Old Jun 22, 2016 | 09:05 AM
haasri's Avatar
Default locks
Just pull the ignition out of the column and take it to a locksmith and they can reset the tumblers to work with your door key
Old Jun 22, 2016 | 11:31 AM
iconoclast's Avatar
i never knew that was possible. i will inquire with local locksmith. thank you.
..mg..
Jun 3, 2016 08:19 AM
rtonder
Jun 13, 2010 07:27 PM
LARANGEROVERGUY
Jan 16, 2010 10:17 AM
sloppyjoe
Jul 23, 2009 10:41 AM
mpmiller1980
Jul 21, 2009 06:30 PM
