May be a dumb question? Fuel tank capacity?
Old Mar 8, 2013 | 10:14 PM
bballjames's Avatar
Originally Posted by nychaze
I dont have an ultra gauge so this might be completely off base, but wouldn't you want to set it to whatever the amount of fuel you always put in? (i.e. i always fill up around with about 20 gal so i would put 20 gal in so that it was dividing the milage over the correct gal)???
That is assuming the UG calculates by know the milage driven over a preset refill capacity? Or do you enter your mileage at fill up and it just does the calc for you?
You do a calibration of the UG. I think over four or five tanks you manually input the amount of gas used and the mileage. Then it becomes even more accurate. And you should also calibrate the distance. Like on mine, every one mile on the odometer is actually 1.3 miles driven.
Old Apr 21, 2013 | 03:46 AM
vipercarcom's Avatar
8th Gear
The real fuel tank capacity for Land Rover Discovery 2 with 2495 ccm (151,48 cubic inches) with other words 2.5 TD fuel tank capacity is: 93.0 litres (24,45 gallons)
Broken08
Feb 8, 2015 01:50 PM
QuakerJ
Aug 1, 2014 06:32 AM
Orkney LR4
LR4
Jan 10, 2014 09:04 AM
armlock
Dec 29, 2007 07:20 PM
bigugly82
May 17, 2007 09:30 AM
