Mechanic did pressure test on cooling system using compressor
Old Sep 9, 2015 | 06:28 AM
tomo's Avatar
Default Mechanic did pressure test on cooling system using compressor
I went to mechanic to check if there are any leaks on my cooling system because Disco losing coolant.
My expansion tank cap is worn, so I tought to order it but wanted to do pressuere test so I can order other parts if needed.
Mechanic removed pipe from expansion tank, took compressor pipe on that pipe to check for leaks , and there was no leak.
I tought he will do simple pressure test, that my old mechanic would do, and not use compressor.
Coolant level is higher that before he have done that, although he spilled some of coolant (because he put air in it?).
Do I have air, now in my system because how he done that, and how to check?
I would not allow him to do pressure test that way but I had phone call, stepped outside because it was noisy.
Please, any advice would be nice.
Thanks
Old Sep 9, 2015 | 07:59 AM
dgi 07's Avatar
Bleed it. You'll be fine. Run at idle, then park vehicle with expansion tank higher than rest of vehicle.
Old Sep 9, 2015 | 09:09 PM
rockbeard's Avatar
7th Gear
idiotic way to test for coolant leaks. don't go back to that nimrod. i agree with the previous poster, give it a good bleed, see that the level is on the mark and roll with that. good luck
Old Sep 10, 2015 | 12:34 AM
tomo's Avatar
Thanks guys.
Will try to bleed system.
That mechanic will not see me again, although I tought to replace fuel injector harness(I have oil on ecu plugs) I will find another mechanic or do it by myself.
tdmadlem
Jun 12, 2014 11:44 AM
94svt50
Mar 8, 2011 06:27 AM
photocrimes
Feb 27, 2011 09:22 PM
dsmtrain
Jun 1, 2008 03:37 PM
jkeving
Apr 11, 2007 11:27 PM
