Melted 02 Sensor Connector
Old May 19, 2022 | 03:24 PM
328Driver's Avatar
Default Melted 02 Sensor Connector
So I didn't secure the O2 sensor wire and completely melted the connector. Any tips or tricks on how to better access the wires to splice in a donor connector? There is no room to work where it is. Bank 1 Sensor 1.
Old May 19, 2022 | 04:48 PM
jastutte's Avatar
i'm dealing with a similar issue. one of the prongs on the truck side plug corroded and broke off.
i have a used plug and wire pigtail coming soon. but i've been wondering how i'm going to solder in new plug. there is very little extra wire and little room to work in there.
hope someone can post up some suggestions for you that i can use, as well.
Old May 19, 2022 | 05:03 PM
zski128's Avatar
I had to replace this pigtail last year. There is a trusted shop near me that I know the owner who helped out. It wasn’t easy but you need to release the plug from the metal bracket which is attached to the bell housing by a bolt. You can then fish up the harness which terminates with the main harness above the bell housing. There is just enough room in the engine bay to pull it up and make the spice.
Old May 19, 2022 | 07:38 PM
RA122125's Avatar
Banned
These work perfect for this repair...ask me how I know, lol. They have both connectors needed, regardless if you are doing a front or rear sensor connector repair.
Amazon Amazon
Old May 19, 2022 | 08:00 PM
keninnc's Avatar
I had this issue also.
Freeing up the wiring harness is the issue.
I had to remove the intake manifold and the left side valve cover. This was to get the the bolt that secures the wiring harness to the rear of the left side cylinder head. Once you get that bolt out and get the O2 sensor connector off it's attachment point on the bell housing and unplug the O2 sensor you can get your access to rewire a new pig tail.
Old May 21, 2022 | 02:28 PM
jastutte's Avatar
i was able to get my sensor plug spliced in, insulated and wrapped up yesterday. Rover runs like it should now with no codes.
@328Driver , not sure what year Rover you have. but it's easiest to work on splicing the wires together if you take off the MAF and intake hoses and SAI valve and hoses. i was able to get both hands into the space and clip the plug, strip the wires and attach the new plug. wasn't always comfortable but it worked. took a couple of hours. but i did take breaks and online research at different times.
Old May 21, 2022 | 02:38 PM
328Driver's Avatar
Thanks everyone. I have a 2004 and it was near impossible to get to the wires from the top. I just finished splicing in a new connector but it involved me dropping the Y pipe to get to it. Now it's time to put everything back together......
Old May 21, 2022 | 09:03 PM
Frank4's Avatar
Glad I saw this. The clip on my plug that has broken and it’s a matter of time before it finds something hot.
Old May 22, 2022 | 07:12 AM
328Driver's Avatar
Fantastic! I put everything back together and the o2 sensor isn't working....let's just say I'm highly disappointed. I'm getting a no activity detected and the sensor is just flat lined at .45v. I swapped upstream sensors so I know those are good. Any chance it fried something other than the connector?
Old May 23, 2022 | 10:57 AM
matt3502's Avatar
You may have a break in the wring behind where you spliced. I had to replace the drivers side when I did the HG's. Thought I got it right but I kept getting codes. I finally gave up and took it to the best LR guy in the state of CT: Holland's Garage in Guilford. After a lot of testing and searching, he found that one of the wires was broken about a foot back of the plug.
