Metal obstruction on inside of front differential fill hole
Old 12-01-2021 | 05:39 PM
redrover75's Avatar
The plastic plug probably just deformed around it. I agree, file it out, but then you have shavings, etc to deal with. Or, just put a plastic plug in w teflon tape and call it a day?
Old 12-01-2021 | 07:03 PM
JohnZo's Avatar
Maybe try using magnets to catch the shavings. Attach one to the file or tap. Place a few under the hole. The shavings should settle down in the bottom anyway, so not much to worry about in my book. Definitely get it tapped out if you plan water excursions.
Old 12-03-2021 | 11:55 AM
SundayFunday's Avatar
Unfortunately a piece of metal in there is no good no matter how you come to realize where it came from.
There are 2 very little rolled compression pins holding the center carrier pin in its place. It is possible to loose one of those pins with mileage (use) -
Are you considering removing 3rd member & inspecting? Those carrier pins are a known Achilles heal.
Old 12-03-2021 | 12:55 PM
disco96sd's Avatar
use brake cleaner to clean the differential - i use about a half of a can for each diff after i drain before refill
Old 12-03-2021 | 02:16 PM
HopeItsNotAMoneyPit's Avatar
So does anybody know the tap size I should purchase to clean out the threads?
Old 12-03-2021 | 02:35 PM
mln01's Avatar
Don't overthink it. Remember, they came from the factory with plastic fill plugs. Those first two threads will hold the new brass plug just fine, even if you bugger them just a little taking out the metal in the back with a rat tail file to get it out of the way for the new plug.
SundayFunday (12-04-2021)
Old 12-03-2021 | 10:31 PM
Alex_M's Avatar
I'd use a spiral flute tap (pulls the shavings out of the hole unlike a straight flute tap) and a shop vac placed next to the hole. That should keep all the metal out of the diff. That, or just grind down the fill plug so you've got fewer threads. There is no pressure on it, so you don't need much thread engagement.
Old 12-04-2021 | 09:54 AM
mln01's Avatar
Originally Posted by Alex_M
... or just grind down the fill plug so you've got fewer threads. There is no pressure on it, so you don't need much thread engagement.
Yeah, Alex and are basically saying the same thing, I think; just different ways to approach it. Two threads (two full rotations) and it should be fine.
Old 12-08-2021 | 09:43 PM
Solved.
GTD 1/2 - 14 NPS is the correct tap size for the differential fill holes. This worked perfectly and corrected the problem.
The following 3 users liked this post by HopeItsNotAMoneyPit:
JohnZo (12-09-2021), Richard Gallant (12-09-2021), whowa004 (12-08-2021)
Alloy
Freelander
12-03-2021 02:14 PM
djkaosone
Build Threads
06-03-2021 09:10 AM
Giorgier
02-28-2020 08:24 AM
calebbo
10-10-2011 10:40 PM
luxury1
01-17-2009 07:59 PM
Quick Reply: Metal obstruction on inside of front differential fill hole
