In the middle of doing fan clutch, help needed!
Old Nov 7, 2011 | 07:35 PM
Snafu / Disco Fries's Avatar
Default In the middle of doing fan clutch, help needed!
So I realized after trail and error that the nut is 32mm and not 36mm. No biggie, I actually found a crescent wrench that was not too bulky that slips right down there. Now for the problem...
I can turn it, hit it with a hammer, etc, but the entire pulley it is attached to turns as well. So, any ideas on how to keep the belt from moving so I can break it free? I put some penetrating oil on it to sit for a bit. I can tell it has been off the car before, likely 1.5 years ago. I just can't find anywhere to stop everything from spinning. Thanks in advance. I jinxed myself saying it was going to be a 10 minute job
Old Nov 7, 2011 | 07:40 PM
Here we go. Push down or pull up on serpantine belt, to tighten. At same time pop wrench with hammer, toward passenger side. Don't pry on pulleys with crow bar, etc. Some have used a strap wrench to fix the fan pulley. It is 10 minutes, after you have done it the first time.
Old Nov 7, 2011 | 07:59 PM
Thanks as always. Having a hell of a time with it right now. I didn't want to wedge anything in by the pulleys and belt and such. Already tried to tighten it up a bit by pulling to no use... let me give it another shot.
Old Nov 7, 2011 | 08:12 PM
Have sometimes put a vise grip pliers clamp on belt and pulley, and let that rotate to stop against something. Can cut belt. Have struck with hammer as if I was attempting to knock a nail in with one blow. Shop towel under belt can ball up and increase tension.
Old Nov 7, 2011 | 08:33 PM
Got it! Will post my trick with a picture later! Phew! Damn glad that is off!
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
