Mirror replacement--99' disco
Old Jan 8, 2008 | 03:01 AM
goldfishy's Avatar
Default Mirror replacement--99' disco
Finally got an OEM driver side mirror, I noticed the new mirror has something that looks like where a AAA battery oe smaller would fit in the back, what is that for? I have not taken off the broken mirror yet, so I can't compare.
But how does the mirror replacement work? There was no instructions, and don't want to pull or push something wrong.
Old Jan 8, 2008 | 09:03 AM
raid13's Avatar
Default RE: Mirror replacement--99' disco
that's were the heater elements get power, you will see the two connectors
when you take off the mirror, if you tilt mirror glass all the way in and look in the opening
with a flashlight you can see the tab you have to move carefuly with a long tool to
get the glass off.
Old Jan 19, 2008 | 05:02 PM
goldfishy's Avatar
Okay, I see that tab I think you're referring to, it's a small white plastic swinging tab, I moved in away from its retainer, but the mirror still locked in place. Does the mirror slide out or pops out? I can't get it to do either and don't want to risk breaking off the other pieces inside.
I may go to a windishield place later this week, but hope I can do it myself.
Old Jan 19, 2008 | 05:33 PM
raid13's Avatar
ok, using long screew flat screew driver. the tab is black
and you will push the tab in toward the body on the outer edge of side mirror
don't worry the inbetween piece with the tabs is
replaceable if you brake it coming off.
hope that helps
Old Jan 19, 2008 | 05:48 PM
How much did you pay for the mirror? I had mine replaced this last fall, insurance paid for it but the total was $35 includung labor, took them 15 min. Did it in the parking lot while my infant son was sleeping in the car seat.
Old Jan 20, 2008 | 03:19 PM
goldfishy's Avatar
Okay, thanks Raid13, it popped right out! Then, I used a little bit of white grease with a Q-tip on the outer edges of the inside retainer and made for an easier pop-in and plugged the two connectors for the heated mirror just before re-installing. I paid $28 for the mirror.
cnterline
Oct 13, 2008 10:13 PM
brw1982
Apr 22, 2008 08:45 AM
PITTDISCO
Mar 9, 2008 07:39 AM
03LRSE7
Jan 27, 2008 09:26 PM
chemeguy
Mar 11, 2005 11:35 PM
