misfire, codes 1300, 0301,0306
Old Aug 23, 2015 | 12:01 PM
BackInA88's Avatar
Originally Posted by Charlie_V
The upper intake is all that you would have to remove. Six bolts and some hoses and electrical connectors. Plus two small bolts that should be on the tops of your coil packs and two more at the bottom.
There is also a small stud that secures the heater core coolant tubes to the passenger side of the plenum.
I remove the flanged nut install a un-flanged nut and lock up the flanged nut against it and remove the stud. Then with your hand under the mounting bracket pry the heater tubes away from the plenum and a small aluminum spacer will drop out.
This is a lot easier than removing the tubes to clear the stud when removing the plenum.
And the best part it you have to remove all the plug wires from the coil so you have enough clearance to slip it out! And I don't have SAI to worry about.
I had the same problem with misfires on the same coil.
I wasn't going to mess around swapping them for a test.
I bought 2 new coil packs and replaced them both, saving the good one for a spare.
It's also a lot easier if you remove the hood.
The bottom coil pack mounting bolts are a real pain in the butt and you have to remove them in order to get the coil packs moved back far enough to get the plenum off. I don't bother putting them back in on my rig as the coil mounting bracket is pretty heavy duty. And then you have 2 spare bolts to use when you drop one of the upper one putting them in.
Old Aug 23, 2015 | 06:00 PM
Charlie_V's Avatar
Ah forgot about that, too.
I use a Harbor Freight magnet to sort of start the bolts I can't reach and am scared of dropping.
outdoor7or24
Dec 16, 2013 05:13 PM
moorebl
Aug 25, 2013 08:26 AM
jbarrios60
Jul 3, 2013 09:27 AM
Eaglerover22
Feb 26, 2012 04:05 PM
mr_boondoggle
Freelander
Jan 21, 2009 05:08 PM
