Misfire Codes
Howdy all, I'm Bob. I have a 2000 LR Disco II. It has 147,000 miles on it and here is what is going on. Last summer I did the Bosch +4 plugs, 8mm magenocores, and the intake seals while it was apart. Just lately, I started getting some misfire codes. They were on 1 and 3. I pulled the plugs and bother were black. I replaced both and made sure that the wires were seated properly on the plugs and on the coil pack. I cleared the codes, but they come back within 30 miles or so. The codes that it is throwing right now are:
P1300 - manufacturer control
P0301 - misfire cylinder 1
P0303 - misfire cylinder 3
P0300 - random/multiple misfire
I'll be honest and say that I don't know what to trouble shoot next. All I can think to do is replace the coil since I didn't do it last summer with the plugs, wires, o2 sensors, and seals. Please hit me up with any thing else I can try before I try to pull the IM again. Since the mileage is climbing up there, I am going to have the fuel system cleaned today after work if possible.
Bob
Bob
Last summer when I did all this work, the truck ran like a champ, it was great! I have been running high test and sometimes medium test gasoline. The truck definitely has a rough idle at the moment. Specifically when it is in gear. If I leave the truck in park or neutral the idle is not as bad, but still not the prettiest it has ever been.
I have not done the coil pack yet, I am going to try to have the fuel system cleaned and hopefully that will do it. I was wondering if there might be anything else to try before just doing the coil pack. Pulling the IM again just really REALLY does not entice me at the moment, hahaha.
