Woo hoo - block leak check done - no leaks!
Old May 11, 2010 | 09:32 PM
audiS4S6's Avatar
Default Woo hoo - block leak check done - no leaks!
If you have not been following my saga, quick run down
bought Disco I
head gaskets blown
removed heads found hole in piston
removed bad piston, cylinder found good
I watched the video for the block leak tester (that sells for $250). I thought it a good thing to check since I had the bad piston and blown head gasket.
I made my own for exactly zero dollars (helps to work some place with scrap metal and hardware). If I had to buy everything it would have cost less than $20.
Anyway, I pressurized the block and no leaks! woo hoo!
Heads are going to the machine shop tomorrow and I am ordering a new piston tonight.
Come on Rover - breath again!!!! Thanks to all that provided direction to date. You have made Disco ownership hopeful!
Old May 11, 2010 | 11:05 PM
greenwade's Avatar
hooray! It is always nice when you find out something is NOT wrong with the discos. It is sort of a love/i was to drive it off a bridge into an active volcano, relationship.
Old May 12, 2010 | 07:06 AM
audiS4S6's Avatar
Ha! Too bad I had to dig so far to find that "something"!
Old May 12, 2010 | 09:15 AM
j.dstasio's Avatar
Isn't that the truth!?!
Glad the block test went well for you. Hope you have your Disco back to life soon.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
glassman66
Jul 17, 2012 08:31 AM
TopherDisco
Jun 3, 2010 08:54 PM
JMON
May 29, 2009 07:27 PM
