Misfire codes, Tune up Help/advice needed
Old Feb 10, 2013 | 09:05 AM
Depends on the wear on the cam lobes. You might read the two stickies at the top of this section regarding valve train issues for more information.
Old Feb 10, 2013 | 12:39 PM
toad2's Avatar
Thanks Mike.
Old Feb 10, 2013 | 12:46 PM
toad2's Avatar
Also wanted to say my mechanic did compression tests and all 8 clys were around 180 psi. Not sure what they should be but that sounded pretty good.
There seems to be a little oil around every sparkplug. Could that be leaking done from the valve cover or is it something else?
Old Feb 10, 2013 | 01:20 PM
The 180 number is good and I wouldn't worry about a little oil around the plugs unless it has gotten in to the plug boot.
Old Feb 10, 2013 | 03:14 PM
toad2's Avatar
No, not that much oil. It's only a little at each plug.
Thanks again.
EHGIII
Mar 17, 2015 10:33 AM
Gromeo
Jan 24, 2013 03:41 PM
davidlafrance
Aug 31, 2010 05:03 PM
Eak69
Apr 4, 2010 12:39 AM
My first Disco
Dec 10, 2006 05:04 PM
