misfire codes307 300
Old Jul 28, 2014 | 09:55 PM
Celto 4's Avatar
Default misfire codes307 300
hi all ive got a 2003 disco 154.000 miles. engine light came on flashing with a slight skip checked codes and it said o2 sensors replaced both up stream cleaned maf and valve. cleared codes and restarted then got misfire codes nothing else. i replaced both coils 6 months ago and used NAPA top line plug wires plugs are autolight i have visually checked all vacuum lines carefully.plugs?change to bosch?thanks for any suggestions
Old Jul 28, 2014 | 10:28 PM
abran's Avatar
Not sure this is your case, but if you can confirm that the misfire is not being caused by your coils, wires, or plugs, could be a blown head gasket that is pulling in oil on the downstroke and causing the misfire.
I bought a car that had flashing SES light and was misfiring, it was the head gaskets.
Is there a misfire code for a specific cylinder? Can you check compression on that one, or if not specific, all of them?
Old Jul 29, 2014 | 07:13 AM
Celto 4's Avatar
Default misfire
thanks yes 307 is cyl 7 i believegoing to check that one
Old Jul 29, 2014 | 07:31 AM
drowssap's Avatar
pressure test and compression test
Gromeo
Jan 24, 2013 03:41 PM
shampro
Audio/Visual Electronics
Aug 23, 2009 09:21 PM
sesese
Aug 9, 2009 02:23 PM
teletechlpi
Nov 6, 2006 09:04 PM
mikemeyer0
Apr 25, 2005 12:45 PM
