Misfire help
Could be a stuck valve.
If you take off the intake manifold
take off the valve cover
take off the rocker arms.
Fill cylinder #5 with a rag or something to keep the valve up.
Take off the valve spring.
Put a drill onto the valve.
Spin it a bit.
Then get the valve spring back on.
Probably bad idea - as this is too hard.
The diesel noise may be a blown head gasket releasing gas toward the outside.
At 30PSI you will not get ignition in #5 now.
You should hear the lost compression if it is a bad head gasket.
If the intake is stuck open, you should get some problems with mixture possibly.
If the exhaust is stuck open, probably not much affected.
But, you would get perhaps a problem with your catalytic as unburned gas will be going into the cat converter from #5.
If you are going to run the engine, disconnect the fuel injector wiring for #5.
You could drive it around on 7 cylinders if you disconnect the fuel injector.
I drove my saab on 3 out of 4 cylinders for a time by disconnecting the fuel injector until I got a new ignition module.
Spin it a bit.
You may as well do the head gaskets. The valve job will come "free" with that.
I would not drive it.
#5 is not igniting the gas that goes into it.
#5 is throwing unburned gas into a cat.
I am surprised you are not getting a flashing check engine light - meaning cats is getting damaged due to unburned fuel.
