Misfire help
Old Mar 9, 2013 | 11:19 AM
Did PSI jump up when you added a couple of tablespoons of oil to that cylinder (helping seal up the rings)?
Old Mar 9, 2013 | 05:23 PM
jfall's Avatar
Could be a stuck valve.
If you take off the intake manifold
take off the valve cover
take off the rocker arms.
Fill cylinder #5 with a rag or something to keep the valve up.
Take off the valve spring.
Put a drill onto the valve.
Spin it a bit.
Then get the valve spring back on.
Probably bad idea - as this is too hard.
The diesel noise may be a blown head gasket releasing gas toward the outside.
At 30PSI you will not get ignition in #5 now.
You should hear the lost compression if it is a bad head gasket.
If the intake is stuck open, you should get some problems with mixture possibly.
If the exhaust is stuck open, probably not much affected.
But, you would get perhaps a problem with your catalytic as unburned gas will be going into the cat converter from #5.
If you are going to run the engine, disconnect the fuel injector wiring for #5.
You could drive it around on 7 cylinders if you disconnect the fuel injector.
I drove my saab on 3 out of 4 cylinders for a time by disconnecting the fuel injector until I got a new ignition module.
Old Mar 9, 2013 | 06:07 PM
trutherford77's Avatar
6th Gear
Added a little oil and it made no difference...still low compression. I just don't understand how the code and the noise aren't there when in park but show up when I try driving it.
Old Mar 10, 2013 | 06:59 AM
mtrdrms's Avatar
If you can, do five again but put a few ounces of oil on the piston. If it doesn't seriously change the psi, the problem is a gasket or valve. I think you have a bad gasket. This is exactly what happened to me.
Old Mar 10, 2013 | 07:03 AM
mtrdrms's Avatar
Nvrmind. Just read you did the wet test. While driving the ignition advances and this dramatically changes the combustion and load on the motor so you will hear the noise much more clearly.
Old Mar 10, 2013 | 09:11 AM
6th Gear
Has anyone had to do a valve job on theirs? What kind of expense am I looking at? If I get it all apart and find out it's just a HG, would it be worth the peace of mind to go ahead and do the valves too? What else should I replace while I have it apart?
Old Mar 10, 2013 | 05:49 PM
jfall's Avatar
You may as well do the head gaskets. The valve job will come "free" with that.
I would not drive it.
#5 is not igniting the gas that goes into it.
#5 is throwing unburned gas into a cat.
I am surprised you are not getting a flashing check engine light - meaning cats is getting damaged due to unburned fuel.
Old Mar 10, 2013 | 08:06 PM
mtrdrms's Avatar
Once the head is off you should be able to see the culprit right away. Figure between 50 and 100 per head to clean and resurface. Unless you see obvious wear or damage to the valves, I would leave them alone.
Gromeo
Jan 24, 2013 03:41 PM
tommytwotone
Sep 22, 2009 05:45 PM
r2racer
Apr 10, 2009 08:53 PM
rravenn13
Oct 15, 2007 08:06 AM
rravenn13
Oct 13, 2007 11:27 AM
