Misfires
Old May 27, 2013 | 09:11 AM
  #21
NickAdams's Avatar
Advance auto has them for $60 each, on the commercial site. Have to order them. May be available by tomorrow.
Good Luck!
Old May 27, 2013 | 09:19 AM
  #22
MtnRunnin's Avatar
Thanks man! I really appreciate it, I've been losing my mind over chasing the issue down haha. I'll start looking around and check out Advance. I'll post up how it turns out.
Old May 30, 2013 | 09:17 AM
  #23
MtnRunnin's Avatar
I changed the coilpacks out yesterday and it fixed my misfire issues. Now I'm getting p0150, p0171, and p01171.
Old May 31, 2013 | 04:54 AM
  #24
NickAdams's Avatar
P0150 oxygen sensor malfunction bank 2 sensor 1. Second code is bank 1 too lean, third code has too many digits. Did you use Bosch oxygen sensors? I did with good results. Wires shorted when pressure washed?
Glad misfire is gone!
Old Jun 1, 2013 | 07:31 AM
  #25
MtnRunnin's Avatar
Sorry, p1171. I changed both pre-cat o2 sensors and its still throwing p0150 & p0171. I'm glad I fixed the misfires but I'm still chasing these codes down.
Old Jun 1, 2013 | 08:23 AM
  #26
NickAdams's Avatar
P1171 is too lean, both banks. Looks like you had P0150 before you changed oxygen sensors. Possible problem with wiring harness (melted wires, open, poor connection.) When I did mine, I used too much dielectric grease on first plug (designed to be air and water tight) and needed channel lock pliers to fully seat and lock connection.
I had diagnosed need for new O2 sensors by monitoring their performance with Scanguage II while driving. New sensors, cleaned MAF, "German" Castrol 0W40 and I average 18 mpg. And to reference another thread, my speedometer and odometer are dead on with gps and highway mile markers.
Old Jun 2, 2013 | 01:09 PM
  #27
MtnRunnin's Avatar
Ya, I wondered about the wiring. I'm not sure what to do about the lean system. I've doubled checked all the lines and connectors, figure I may try the replacing the fuel filter? The odd thing is that the codes don't throw a SES light, but they show up on the code reader. It also has a rough idle in in gear, but runs like a sewing machine once you start moving.
damnlows10
Mar 4, 2024 07:53 PM
Jawbox
Oct 10, 2007 09:14 AM
japt29
Jul 19, 2007 09:24 AM
hendoc3
Jul 18, 2007 03:10 PM
whodey
Mar 6, 2005 01:49 PM
