Misfires, again
Old Feb 1, 2010 | 12:21 PM
bbdesoleil's Avatar
6th Gear
Default Misfires, again
First of all, thanks to everyone on this forum for the advice that has at least gotten me to this point.
I have a 2000 Disco SD7 with 125,000 miles
I have owned it for 18 months and have replaced the head gaskets, radiator, plugs (+4's), wires (magnecors), 2 coils, 2 cats(kept the exhaust), water pump, 4 sets of pads and one rotor. I have no problem with maintaining the vehicle as it is still less that a car payment and I have a great truck. I run premium fuel but have not done the seafoam treatment nor the techron since I purchased it.
Here is the dilemma.
I get the Service Engine Soon light occasionally (every couple of weeks) It flashes for about 10-15 seconds then stays lit. It will clear after a few starts.
The codes I got the last time are P1300, P1304, and P1305. I have been getting P1304 somewhat regularly.
Here is the question.
Am I far off thinking I should check the MAF? The mechanic pulled up the codes, looked up the recommendations and we thought it might be low fuel pump pressure. I'd prefer the MAF as it seems far less expensive.
Any recommendations on where to proceed first would be helpful. The P1300 with the cat damage is scarier than I am comfortable with to continue driving.
Thanks.
Dan
Old Feb 1, 2010 | 04:08 PM
thechidz's Avatar
whenever I hear misfires, if it's not plug wires (which you changed) I think ignition coil
Old Feb 1, 2010 | 04:51 PM
bbdesoleil's Avatar
6th Gear
Unfortunately, I have already changed the coils also.
Old Feb 1, 2010 | 05:20 PM
hilltoppersx's Avatar
i dont think the MAF would cause those types of misfire errors. none the less what type of air filter do you use? i hope the paper type and not K&N.. as for the errors you have since you did the coils maybe its the EGR valve in combination with something else? they are all generic severe misfire codes causing cat damage...
Old Feb 1, 2010 | 07:49 PM
Rovin4life's Avatar
spray some water on it to see if it acts up.
Old Feb 1, 2010 | 08:11 PM
bbdesoleil's Avatar
6th Gear
Interesting that you mention that. The SES light generally seems to occur a few minutes after I leave home and I read on other posts that some engines misfire as it warms up and burns of moisture.
Other than the SES light, is there anything else I should notice?
Old Feb 1, 2010 | 08:13 PM
bbdesoleil's Avatar
6th Gear
hilltoppersx:
I know that I do not have a K&N filter. Also, I'm sorry for the ignorance, but what is the EGR valve?
Old Feb 2, 2010 | 11:23 AM
exhaust gas recirculation, its part of the emissions system that reduces nitrogen oxide out of the exhaust. it returns part of the exhaust back into the cylinders. maybe that is what is causing your misfires and messing with your cats....
Old Feb 2, 2010 | 11:34 AM
gowest's Avatar
MAF would have a different set of codes. Including a shift / transmission fault code.
Old Feb 2, 2010 | 11:45 AM
bbdesoleil's Avatar
6th Gear
Thanks for the input. I'll have the EGR checked. I'll keep you allposted on the progress.
abran
Jun 30, 2014 12:43 PM
Jawbox
Oct 10, 2007 09:14 AM
japt29
Jul 19, 2007 09:24 AM
hendoc3
Jul 18, 2007 03:10 PM
whodey
Mar 6, 2005 01:49 PM
